Old 03-20-2008, 09:32 PM
cobrajam's Avatar
cobrajam cobrajam is offline
Cobra Make, Engine: Contemporary frame, Midstates kevlar body, Aluminum Shelby 427, G-force T-5
Default Dummy Pedals
After setting body on, I cut slots in botton of footbox relative to the Contempory brackets. I made up some cardboard clutch/brake arms and installed to see where I needed to adjust for fit. With a straight arm, the brake is about 5" from the trans tunnel. The clutch is 4" to the left of the brake, and about 6" to the right of the outside of footbox. The arms also appear to need to be bent/curved towards the driver as the attachment points are almost clear to the front of the footbox, as well as needing bent 1" or so to the outside of the footbox.
Does anyone know how far from the front of the footbox the pedals need to be, and also the spacing for the pedals?
