Old 03-21-2008, 07:14 AM
mickmate's Avatar
mickmate mickmate is offline
You'll see ERA is using a common mount for the brake and clutch hence the big offset bend on the clutch. Your pedals need a good offset to get them over as Jeff says for gas pedal. The ones we've been making have a 7/8" offset you might want more than that. I would suggest also cutting your slots back further so the pedals can get back from the footbox front and give you some travel. Jeff with the inch of clearance of the back of the box to pedal it gives about 8" from footbox to pedal pivot on my drawing. You have the "working" model so the 7" you said should be close. That's good progress on them, keep going! How's do they look from underneath?
mickmate
http://www.actoncustom.com/
