Old 03-21-2008, 01:59 PM
cobrajam's Avatar
cobrajam cobrajam is offline
Cobra Make, Engine: Contemporary frame, Midstates kevlar body, Aluminum Shelby 427, G-force T-5
Using the Contemporary mounting position, I am kind of limited as to where I can bring the pedals up through the floor. That is why on one of my previous posts I attached the pic of the template and it had a curve back towards the driver, since the Contemporary is so far forward in the footbox, that is the only way I could think of fabricating it to get full pedal travel. The last picture I posted almost looks 2 dimensional, when in fact the pedals are resting about 6-7" behind the front of the foot box. In addition, I should be able to get some adjustment depending on how far I screw on the heim joints to the masters (?) I could probably make these work, but how far from footbox should they set (I guess I will need to install the accelerator pedal assembly too and get some relative measurements). I was just curious what the typical spacing was, and it does seem to be at least an 1" or so tight to the inside.
