Old 03-21-2008, 02:48 PM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by My427stang View Post
I'd run a 950 HP as a minimum, but would advise you go with a 1000 HP Holley or an 850 Barry grant or 850 QFT
The 950 is a misnomer, its a 750 with an 850 baseplate and isnt a very big carb for what you have.
The 950 is a good carb, but it is smaller and will lose top end charge, but gain you nothing down low over a modern 850 or 1000 HP.
I looked it up, and you're right, the 950HP carb has similar venturi diameter of standard 750, but throttle plates of an 850. As the 950HP carb has a recountoured/reshaped top entry for better flow compared to a standard 750, I'd think it would therefore flow more, but bby how much I don;t know. Obviously, Holley thinks that the carb should be rated at 950. Does removing the choke tower/reshaping the entry zone improve airflow that much? How much restriction is in the venturi diameter or base plate throttle bores/plates?
Interesting.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
