Old 03-22-2008, 11:47 AM
427sharpe's Avatar
427sharpe 427sharpe is offline
Cobra Make, Engine: A CSX Cobra,1966 GT350 and an '06 Ford Heritage GT
The '90 gearbox should have the 8 tooth drive gear (inside the trans), and you need a 2.33 ratio; if your speedo is pegged to 1000 RPM @ 60, which is pretty much standard. So look for a 19 tooth gear. If yours has the old 7 tooth drive, look for a 17 tooth gear. You can see the internal gear thru the speedo cable hole, the 8 took gear is green, the 7 is yellow. 6 is also available, and is black. It would be a part installed during a rebuild at some point. If you see that one, you need a 14 tooth gear. This combo would be the most accurate for you if you have the trans out and can replace the drive (internal) gear.
"I think we have more machinery of government than is necessary, too many parasites living on the labor of the industrious." Thomas Jefferson
