Old 03-23-2008, 12:48 AM
FST FOX's Avatar
FST FOX FST FOX is offline
Cobra Make, Engine: #42 BDR w/ a 408 KCM stroker
Originally Posted by Rwillia4 View Post
1) flushing the clutch is a pain because it doesn't take long ot empty the reservoir, I found a small oil squirt bottle works well. chances are you still have air.
2) check the ground strap ( I had the same problem but I can't remember exactly how I fixed it)
3) Is this the same carb as the previous engine? it might need an additional return spring.
1.) I have a plan for the clutch, but I think you are right, it's slowly was building pressure, just not enough to make the pedal come back
2.) only thing that changed was the gauge wire, power wire and ground were untouched
3.) it returns fine if done at the carb, I think I have an issue with my actual cable
2006 King Ranch F150 Supercrew
Personal vehicles-2007 Escape
2004 BDR #42 with a 408 Keith Craft Stroker, Crimson with Silver stripes
