Old 03-23-2008, 05:17 PM
Scott S's Avatar
Scott S Scott S is offline
Charter Club Cobra Member
Cobra Make, Engine: My Shell Valley Coupe is here! Now the building begins....
If you have the 4 nuts off try putting the wheel and tire in a slight bind towards the nut you need to remove. Sometimes the increased friction on the backside or the stud will help.
You will need to replace the stud that is giving you trouble, be sure to center punch around the hole after you insert a new one. Doing the same for the others wouldn't hurt also.
scott S
Working as hard as I can every day to double my carbon footprint.
