Old 03-25-2008, 05:02 AM
Default Check 3 things
wanab5150 Check 3 things, First do a manual bleed of the rear system. do it slow and easy put a clear hose on the recovery bottle and watch for bubbles. Do this about 4-5 time Tap on the rear calipers to make sure there is no air in them. Next How where the brake pads broken in?? You are giving a way to break them in with glazing them. If you glaze them you need to sand the pads on a flat surface, same with the rotors. Go out and drive the car do 5-10 medium pedal stops to 0 mph. After the stops, go and cruise and let the rotors and pads cool off, REPEAT this process 3 times. You should have good rear brakes. The other thing is whos pads are on the car. You might have a carbon kevlar compound that needs alot of heat to work properly. If these 2 things don't help you need to go and get pressure gauges for measuring the clamping force of the calipers. I don't know what the correct pressure is for your car, I am guessing 900 to 1,100 lbs for the rear. Dennis O. should know. If pressure are low, on both, the master cylinder is bleeding down internally and will need replacing. Good Luck Rick L.
