Old 03-26-2008, 11:30 AM
bigrob's Avatar
bigrob bigrob is offline
Cobra Make, Engine: BDR # 126/ K. Craft 306 CID/375 HP- 306 RWHP
Originally Posted by J Persons View Post
It's probably heat soak into the carb. My car does the same thing in the summer when the air temp is over 100. About the only cure is to isolate the carb from the engine using an insulated spacer, or a turkey pan that seals against the bottom of the hood. Holley sells an aluminum plate and spacer that is probably better than thean insulated spacer by itself, but still probably not as good as a turkey pan.
Thanks for the info. I may have to do the turkey pan. Do you need to remove the carb to istall it? I remember the PO telling me he had a hot starting problem as well, but said it was the coil getting too hot & due to the fact that is was mounted to the motor. He relocated to the fender wall.
Thanks again!
Rob
" Listen to that music! "
'65 BDR #126
'84 Porsche 928S
'01 Corvette C5 coupe
'99 Ford Explorer Limited
