Old 03-26-2008, 12:12 PM
SP01715's Avatar
SP01715 SP01715 is offline
Cobra Make, Engine: SPF1715, Roush Built 434 ci Stroker, Dart Block, Ported AFR 205 Heads... 561 hp / 547 tq, Former Roush Show Car, Completed and Prepped By Olthoff Racing.
Originally Posted by rdorman View Post
I spin the bits backwards, prevents the bit from lifting the gel coat.
You can also use a counter sink bit before you drill the hole to cut away the gel and prevent it from lifting when you drill into it. This is a trick I learned from a guy that rigs custom boats.
