Old 03-27-2008, 03:14 PM
4RE KLR's Avatar
4RE KLR 4RE KLR is offline
Originally Posted by meat View Post
Nope.
If you slam on your brakes to stop short - 'lock up your tires' was the term used above - then YOU are the one who is doing the reckless driving. YOU are the one not in control of your vehicle. YOU are the one impeding the right of way. YOU are the one who is primarily at fault. YOU are the one that 'causes physical contact' not the other driver. I'd make sure you were thoroughly investigated to see if you're part of a swoop and squat scam.
Your pal,
Meat.
Nope, your wrong.
If I stop, regaurdless of why I stop in ANY siuation emergency or otherwise if you hit me from behind and we are both in the same lane traveling the same direction you are at fault, you are following too close.
I would advise you to check your highschool drivers ed book before giving your opinion a whirl.
