Old 03-27-2008, 05:17 PM
thorconstr's Avatar
thorconstr thorconstr is offline
Cobra Make, Engine: ERA 427" 351W
Default TWM 427 Fe
Thor Motorsports
Competition Fuel Injection
Systems and accessories
Al Wohlstrom
7890 East Starbright Court
Tucson, Az 85750
Cell 520-401-9142
email thormotorsports1@msn.com
www.thormotorsports1.com
All of the new airhorns will have a groove machined on the inside bottom edge to accept a piece of #14 304 stainless that will be secured between the throttle body and airhorn. We will have finer mesh available that will fit inside the airhorn on top of the #14 that can be removed for cleaning. This will give a level of filtration, and minimal restriction while not taking anything away from the clean look of the airhorn. Please note the new less expensive ECU I have added to try to lower the cost.
Re: TWM injection for 427 FE Ford
427 FE Ford application includes four 58mm two barrel throttle bodies, manifold, manifold mounted linkage, vacuum plenum, fuel rails, tps, regulator, and air horns. Retail $4,785.00 Your price $4,065.00
F.A.S.T. XFI ECU, wiring harness and O2sensor 2,190.00
F.A.S.T. injectors 42 lb/hr 655.00
MAP, water, and air sensors 110.00
Aeromotive fuel pump, and filter 450.00
Throttle cable 105.00
Shipping 75.00
Total $7,650.00
Optional ECU, delete FAST $1,850.00
Nostalgia air horns with screen/foam filters ( like Webers) 400.00
We are working on filters that will work with the reduced hood clearance of a Cobra
Optional polishing of manifold, throttle bodies, plenum, linkage, air horns & fuel rails $1,650.00
I require 50% deposit to place the order an 50% when the order ships. I take Master Card & Visa. Thanks, Al
Al W.
