Do you want to autro cross or road race? In my opinion, the 350 lb front springs are too soft for road course. They decent for autocross. Removing the front sway bar will lead to more body roll and less understeer. Adding the CR rear bar will result in more oversteer. The two actions combined will cure a sever understeer or lead to greatly increased oversteer. Is your car understeering? I run 500 lb front springs along with the CR supplied bar. Along with the small bar in the rear, car is fairly neutral with no significant roll. This is with a 351W based engine. Car is nearly perfect front to rear weighting and cross weighted. Also, this is a road race setup. I find autocrossing an exercise in frustration.
