Old 03-30-2008, 07:22 PM
63mercury's Avatar
63mercury 63mercury is offline
Cobra Make, Engine: Scratch building frame,FFR Mkll body ,302w, and T5 trans, 3.0 rear.
Thanks Patrick, I will try that for my next post. I have the cowl hoop tacked up and tack mounted onto the outriggers, modified the tie rod ends to get the toe in set, will order the proper parts for final assembly. will post pics in the next couple days. Will be going to the scrap yard in the morning to check out the T-bird rotors for fit, they are 10.5 in dia and the caliper brackets will allow standard parts to be used ( all Ford no GM stuff). Carl.
1963 Mercury Monterey 460+ .060 .//Cobra clone, Scratch build frame /302/ T-5 WC / 3.00-9in/FFR mkll body (Broken but repairable) /91 Lincoln Wire Wheels // : N.S.M.C Charter/Life Member// Die Hard Blue Oval Nut
The finish is better than the beginning. Ecc7:8
