Old 03-30-2008, 08:08 PM
lemans24 lemans24 is offline
Cobra Make, Engine: kirkham stroker 48 webers
Default could use some help with tko 600 instal
Hi guys: Installing the drivetrain now. got the engine in fine, the motor mounts are loose. I put the tranny in thru the inside of the car. the tranny will not go any further forward. its right up to the collar that rests inside the hole of the bellhousing, but will not go 1/4 in. forward. The mounting bolts are just about lined up. I have the engine jacked up alittle at the bellhousing(lakewood). Any words of wisdom????
