Old 03-31-2008, 05:32 AM
Murphy's Avatar
Murphy Murphy is offline
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
Default I had the same problem
I found my was hung up on the powder coating on the scatershield that you wrote you ground off. I noticed on mine that the fit of the pilot bearing is an exact fit and it helped that I put some powdered grafite on the shaft and bearing. Makes your back hurt along with your head.
