Old 03-31-2008, 09:23 AM
BDHE's Avatar
BDHE BDHE is offline
Cobra Make, Engine: Superformance, PE 514
Originally Posted by Bob In Ct View Post
Bryon:
Remember, negative camber is bottoms out.
Thanks Bob!
Mike from Dynamic in Ohio sent me the following specs:
Tire pressure 20-25 front and rear
Front Camber: -1/2 degree (+ or - 1/2 degree)
Front Caster: +4 degrees (+ or - 1 degree) set even both sides
Rear Camber: -1/2 degree (+ or - 1/2 degree)
Front Toe: In 1/16th each wheel, total toe 1/8th inch
Rear Toe: In 1/16th each wheel, total toe 1/8th inch
and from Bob -- Negative camber is "bottoms out".
