Old 03-31-2008, 10:49 AM
DAVID GAGNARD's Avatar
Tony;
I don't know a whole lot about Cleveland engines, but 10 psi at idle and 25 psi at speed sounds way too low to me on any engine......
I have used at least four different brand oils and weights as well as synthetic oil and my oil pressure did not vary more than 5 psi from the different oils....I presently use Mobil 1 15/50........
I would install an oil pressure gauge that you know works well or you have tested and check the oil pressure before doing anything else.....then go from there........
David
DAVID GAGNARD
