Old 04-02-2008, 05:31 PM
SSSammy's Avatar
SSSammy SSSammy is offline
Default Needed equipment
Chris, do you have an engine hoist with chains and either a tilter or a carb plate to attach the hoist to the engine? That's the biggie. We can bring these things if you do not have them, although the hoist is a real pig to haul.
Also need at least two jack stands to suspend your car while we take a wheel off so the hoist can roll under the body. A floor jack is needed to put the car up on stands.
Then you will need a socket set and some box wrenches in SAE sizes.
That's about it for a pull. Don't know how the tranny is in your car. Do we need to remove it? Does it go in through the cockpit or from under the car? I have a tranny jack if needed. Also let me know if you want the generic engine cradle I have. We might have to cut some angle or something to make it adapt, but maybe not. If jdean brings his welder we can modify it if necessary. I do not care if we booger it up, I don't need it.
Sam
