Old 04-03-2008, 12:49 AM
Baz's Avatar
Baz Baz is offline
Originally Posted by Mando View Post
Hi Baz, does the bar that attaches to the chassis bolt in the same place as the Jag upper arm or do you need to make adjustments.
Regards.
Mando,
I've checked with Neil so disregard the info in your PM. This is what he has told me to do.
"The Upper Arms require either a plate to be drilled to the same bolt pattern as the Arm and then welded to the chassis or fill the existing Arm mounting holes with weld then re-drill to suit hole pattern of the new Arms."
Either way, it is a very simple modification and you will be extremely impressed with the results that you achieve.
Baz
