FYI - The wheel well padding is installed on SPF2168. I purchased the pre-cut padding from Top of the Hill in Livermore and had Jeff (Club Cobra ID: "CSX WNAB") Installed them.
It took a bit of work to remove the original SPF padding, but Jeff did an amazing job. The new installed padding covers the entire upper wheel wells. Jeff's install looks as good or better than if it came from the SPF factory. when I get a little more time I will post some pictures of the process and finished product.
I highly recommend Jeff ("CSX WNAB") if you want any work done on your Cobra and you are in the SF Bay Area. Once you see his SPF and CSX's he has worked on you will know why I recommend him. You can usually find him at the NorCal breakfasts in Livermore on Saturday mornings or pm him on this site.
Dan
