Old 04-04-2008, 09:31 AM
danc30's Avatar
danc30 danc30 is offline
Cobra Make, Engine: Hurricane HM1073 Keith Craft Genesis 427FE/482 CI
I replaced the return regulator with a dead head and it fixed the problem. Now I know what was causing it. It was a bypass regulator trying to work with an internally bypassed pump. These 2 don't work well together. I am still deciding whether to replace the pump with a non-internal-bypass one or stick with the dead head.
The pump I have is run through a relay within 12" of the pump, I have about 4 feet total of braided line between the tank and pump and at the front transitioning from the alum. line to the filter regulator in the engine compartment. I have 1/2" aluminum line from the pump to the front of the car as well as from the regulator to the tank as a return line.
Jerry,
I just want the electric. Also there isn't much room for a mechanical in my engine compartment.
Undy,
You say the black pump is externally regulated. Does this mean I can shim it so it doesn't regulate at all so my regulator in the engine compartment does all the regulating/bypassing?
Thanks for all the help.
