Dash Board Wiring
Hi Everyone,
Does anyone have any pictures of how you bundled, routed, and attached the dashboard wiring to the dash?
For my initial attempt at wiring the gauges, I tried to keep the wires relatively short and just ran them directly from one guage to the next. After pondering it for a while, I decided that the wires flopping around probably wasn't a good idea so I'm going back to redo the dash and wanted some ideas on how to do it better/right.
I'm thinking that I should run all of the wires thru a central bundle that I can attach to the dash and then break out the wires to run each gauge from the bundle. If the dash was wood, I'd could staple the bundle to the dash but with fiberglass I'm not sure what would be the best approach to secure the bundle while allowing it to be removed if necessary.
