Old 04-06-2008, 06:20 AM
trularin's Avatar
trularin trularin is offline
Member of the north
Cobra Make, Engine: A Cobra
I can give you a few pointers for wiring.
1. Try to use solder and shrink-wrap-tubing. It will hold up much longer and will look better.
2. "Half a finger" service loop is good. If you have a harness running up the middle of the gages, just before you connect the wire, pull it over your finger.
3. Wire in one direction. If you like left to right, then do left to right.
4. Heavy plastic split harness dress make the job easier, It is a heavy plastic spiral that goes around the wires.
5. Color coordinate your wiring. Ever had to find the red wire and find more than one?
6. Use #18 wire as a minimum.
7. If you can manage it, a bundle connector makes working on electrical a bit easier.
8. Labels are great. Don't be afraid to label your wires.
There are several others that can be listed, but if you use a bit of common sense, it can be done with great results.
Hope this helps.
