Thread: Hard Starting
Old 04-07-2008, 11:51 AM
Default Check the gap
WillB Depending on access and weather you have the car together or not with the trans in, You want to engage the soleniod of the starter without the motor spinning. On an FE motor I tighten down the motor block plate and mount 3 starter bolts to this. There is a wire that goes from the starter soleniod to the motor, unhook this so the motor will not spin. I have found that a thick paperclip works great for stick between the extented drive and the flywheel teeth. Adjust to get the right clearance with either rotating the mounting plate, adding shims, or removing shims. You can just stick it in and try it. If the engage and release sound OK, you are in the ballpark. If you hear the grinding or whining sound, you are too close or too tighen in clearance. I did mine with the trans and bellhousing out of the car, motor was still in. Rick L.
