Old 04-08-2008, 03:50 PM
Jerry Clayton's Avatar
Jerry Clayton Jerry Clayton is offline
Terry
Switch wires at the cap for #1 and # 8----it is common error to mix these two wires up as when you look at them they look correct when in many cases they are reversed.
Also make sure your wires are separated as cross firing between 7 & 8 was common .
Back in the day----people would line up the wires 1234 on the right side and 5678 on the left side whhen really the factory correct wire placement was 7568 on the left which put three wires on wrong---always happened with a tune up of an engine that was running fine before hand
