Thread: MSD Issue
Old 04-09-2008, 06:48 AM
FatBoy's Avatar
FatBoy FatBoy is offline
Cobra Make, Engine: Kirkham #523, 427 S/O
Originally Posted by Barry_R View Post
Make sure that your 12v "key on" connection also has 12v while in the crank position. Some ignition switches may separate the two because factory points systems use a resistance bypass circuit (tied into/fed from the "I" terminal on the old Ford starter relays).
Interesting point Barry. I hadn't considered that. However, I believe I have wired it into the correct point as recommended by Kirkham. But it is worth checking. Thanks.
Dan,
Might sound dumb, but it was still worth asking
Thanks,
Paul
