Old 04-09-2008, 05:39 PM
AC Cobra's Avatar
AC Cobra AC Cobra is offline
Cobra Make, Engine: Venom 351W
Originally Posted by rattlesnakepete View Post
AC,
I have the same cam you mentioned. Mine was made in either 2005 or 2006. I have been keeping an eye on the cam and distributor gear and so far so good. I have about 1200 miles on it mostly at the track.
How long did yours last until it stripped?
I wonder if I can check the production number on the cam and see if it was from the bad batch?
I am not sure if comp cams would fess up to any of this unless I have a failure.
The original CompCams 35-426-8 had a serial number of UE0920. If you have anything close I would call and talk to CompCams.
My original cam lasted about 3 years before it failed. I was using a steel gear on the MSD distributor.
AC
