Old 04-10-2008, 03:43 PM
olddog olddog is offline
Default 5.0 Intake install questions
Keith,
I have Edle Vic Jr intake and Edle Performer RPM heads. The bolts were stainless with a thin stainless flat washer against the intake and a stainless lock washer on top of the flat washer. I had problems with the bolts not staying tight. They would loosen in about 4 heat cycles. I was only going to 16 ft-lb per Edle instructions of 16-18. Since there was RTV fairly thick at the water ports, I'm not certain that the intake was ever tight up to the head. So with vibration maybe that is why they were working loose. However, I have had many people on this site tell me they have to re-torque often.
When I took it apart the flat washers are cupped now, and the lock washers are completely flattened out (no spring left at all). I know stainless is not the best fasteners, but with aluminum I don't want to paint steel bolts and hate rust.
I am thinking of lock tighting steel studs into the head. Use a good thick flat washer stainless. Tighten with a stainless nut. Then use a stainless acorn nut to jam (lock) the first nut into place. Good Idea or bad idea? What do you usually do?
Next question. The gasket opening is much larger than the water ports. This is corroding the flanges. Should I fill (not over fill) this area with a sealant? I am using "the right stuff."
What should I torque to? I was thinking 25 ft-lb, but that may be too much.
