Old 04-11-2008, 06:28 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
I have been there and recently, but you might need to disconnect your steering shaft to gain a little more access. However, if you are pushing water through the side pipe and I assume it is on your drivers side probably pistons 6 and 7, you may want to pull the engine and do it right. Or if you want to wait until this fall to do it get some bars stop leak and follow the instructions on the bottle and see if that helps. This stuff works pretty well in fact it got me through Run and Gun last year until I could pull my engine and resurface the heads and block.
Good luck with whatever you decide.
Clois
"Let's roll"
"Be part of Something Good
