Old 04-11-2008, 07:36 AM
Power Surge's Avatar
Power Surge Power Surge is offline
The belt rotation only matters if it's going the same way the water pump goes. You may need to pull the pump and check the impeller direction. If you're running the older rotation pump on the serp setup, you can be rotating the right way for the BELT, but not for the PUMP.
Sal Mennella
