Old 04-11-2008, 05:42 PM
Bartruff1's Avatar
Bartruff1 Bartruff1 is offline
Cobra Make, Engine: Midstates/Shell Valley Street Cobra
Default OK....what do I look for ?
I'm going to picking up a new Superformance MK3 in Reno this month...based upon what I have read in here I should...open every door...switch every switch... make sure the brakes are working as designed....check the ride heigth , should be 27"...make sure there is no ground connected to the radiator... make sure the speed o cable is the right size and length so the speedo doesn't bounce make noise...check the fluids...go over every inch of the body ....check the wheels for any damage and...warm it up and run and stop it hard.. let it sit and check for leaks...and.. ??? Thanks in advance for any advice...
