Old 04-12-2008, 07:55 AM
olddog olddog is offline
Jac Mac,
The bolts are correct and the taps I used - 5/16 - 18.
The other eight holes, I can spin the bolts and the taps down with my fingers, with ease.
I agree something was wrong with these four holes. I suspect they were not right from the day they were new, as it is suspicious that it is the 2nd hole from the end both sides on both heads. A pattern makes me think a manufacturing problem, but since I have no history to back it up, I may be flat wrong.
I would guess the heli-coils are lock tight or other wise glued in. I'm concerned on how to get them out. Should I heat a bolt with a torch to loosen the glue before trying to get them loose? With out at IR gun to monitor the temp, I'm worried about the aluminum.
