Old 04-16-2008, 11:35 AM
DAVID GAGNARD's Avatar
Why would a 347 stroker with max RPM of 6000 ever require a carb with more than 600 cfm? Please explain with math if possible.
Holley's own formula is very simple for this;
Cubic inches X max rpm divided by 3456 = cfm needed at 100% volumetric efficency....
347 cu in X 6000 rpms= 2082000 divided by 3456 = 602.43 cfm of air at 6000 rpms...
assuming the motor is about 95% efficent, then you still only need 572.31 cfm of air at 6000 rpms..........so therefore a 600 would be perfect.....
over the years I've tried at least 6 carbs on my 350hp, 351-W, ranging form 600 cfm to highly modified 750's.... tested on the street for fuel mileage and the 1/4 drag strip for perfomance, the clear winner was a 20 year old Holley 600 double pumper in both catagories.... the second place carb was a 600 vac sec carb and the worst was the 750...................
The 600 dp gave 6 mpg better fuel ecomony on the highway and .2 a second faster in the 1/4!!!!!!!!!!!!!!!!! it suprised the heck out of me as I THOUGHT the 750 outperformed it on the 1/4, the time slip does not lie...............
David
DAVID GAGNARD
