Old 04-16-2008, 02:39 PM
blykins blykins is offline
1. If your engine makes power at a high peak, you need more carb. You would also need more carb in a constant WOT throttle situation, like drag racing.
2. I have no clue.
3. Yes. Especially with larger duration cams and a tight quench.
4. Why would you?
5. I think it's 6 of one, half dozen of the other. I usually select a piston based on the combustion chamber. Sometimes, you can't open the chambers up enough to get the CR down, so you have to run a dish piston. I shoot for pistons at zero deck and .040" head gasket thickness, so I get a real tight quench. As long as the quench pad is tight, I don't see a problem with big dishes. I consider it poor practice to put the pistons way down in the hole or use an incredibly thick gasket to put ratios where they should be.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
