Old 04-16-2008, 05:14 PM
Great Asp's Avatar
Great Asp Great Asp is offline
Cobra Make, Engine: SPO 2715
Originally Posted by thudmaster View Post
I did not cut the plate but I did notch the frame. I took about one and a half inches out of it. Bolted it on and it works fine. Intresting enough I did not have to do anything to my last spf.......
Same thing here. You only need the top two bolts, but I recommend that you apply a couple of those heavy felt stickers (you can look in Lowes or Home Depot in the hardware section) to the back lower part of the plate, in case someone presses on it, or you slam the truck. Keeps from the plate scratching the paint.
E
"The Shelby frame will not fit on my car. It is hanging on the wall in the garage instead." My Shelby plate fit....go figure
