  #31 (permalink)
Old 04-16-2008, 11:27 PM
vanoochka's Avatar
vanoochka vanoochka is offline
California Dreamin Member
Send a message via ICQ to vanoochka Send a message via Yahoo to vanoochka Send a message via Skype™ to vanoochka
cdog.
The push button I used - from Finishline - fit perfectly into the hole left by removing the key assembly. However, there is a little more to it than a straight trade out - key assemblly for push button - as you need to wire the "accessory" setting into a switch. Putting the switch into the on position is as turning the key to the first position after inserting it. Pushing the button is as turning the key to start.
I suggest that you buy the wiring diagram that Blas sells. Having it makes the project a breeze.
