  #80 (permalink)
Old 04-17-2008, 09:43 PM
wanab5150's Avatar
wanab5150 wanab5150 is offline
Cobra Make, Engine: Superformance #2769 Roush 427R Dart Block
I talked to Stephen in Reno today. He was already contacted by Olthoff with the run down on the new caliper set up that is in the works. Stephen was told that since the old caliper mounts at the 3 o'clock position on the right rear of the car, the new brackets will mount the new 4 pot at the 9'o'clock position. The brake line will be removed from the old caliper and attached to the new one.
So you will temporarily have both calipers on the right rear wheel until the e-brake issue is solved. The old caliper will serve as an e-brake because the e-brake cable is mechanical, not hydrolic and therefore does not need fluid. As soon as a solution is found for a new replacement e-brake, that will be sent to everyone to retro onto their cars........oops......except Thudmaster...he doesn't get a new one. lol
This should be easy to do at home, but I would THINK Superformance would have a shop perform the work for you if you wish. Thats the latest....tom
Tom
I miss my Tazer
