Old 04-18-2008, 05:30 AM
Default Grassroots racing mag for brakes?
Clois The fast mustangs and super ford mag has alot of brake kits for sale in there. 12" rotors are the biggest to fit in a 15" rim and leave a little air to blow around. Get rotors that are slotted and stay away for the drilled ones. Drilled ones can crack under hard racing, SBBC make a whole bunch of different brake pads with different materials for hard braken. If you are going to run hard, a would add the little 4" blowers to both front wheels. You can get the air from either the 2 holes in the front of your nose that is used to blow air on your feet, or buy the originial brake ducts for the front and back rotors from Enzo. I think Morris has these in the front of his car. The blower kit, relay, and switch would cost about $90.00. For the rotors and pads, you may want to try Summit or Jegs. Just a thought. Rick L.
