Old 04-18-2008, 07:45 AM
madmaxx madmaxx is offline
Excellent work and effort Wanab5150. I should be obtaining my new SPF pretty quick, probably days. As far as brake caliper replacement did the mention how it would be handled? I have not pressed the issue but the response I keep getting is they appeared to stop fine but it sounds like in recent days SPF has aknowledged the problem so the response will probably change. If I understand no new brackets or machine work will be required? If that is the case then the remedy should be fairly straight forward, install calibers, connect hose and bleed. If the other brake is working well as an emergency brake why not leave it on there? I guess SPF will have to decide it.
