Old 04-20-2008, 10:15 PM
Three Peaks Three Peaks is offline
I got the DR 4855B and DR 7855B (single adjustable) for my build, but you'll need to check your car for what length shock you need and check his list for which will work for you. Just measure the length from eye to eye on your present shocks with the car at ride height.
Same for the springs, you'll need to do some calculations to see what is the best size for your car. After doing the calcs on the QA1 website and checking with a few buddies with FFR cars, I went with 500 lb front springs and 550 lb rear springs.
I won't know if I got it right for a bit as the car isn't finished yet.
Bob
