No whining!
OK, big thanks to Jim and Eric yesterday!
Motor is back up and running! She is purring like a lion and I put about 100 miles on the rings to start the seating process.
The 429 started smoothly after Eric helped with the 180 out issue. I need to put some more miles on the car then adjust the valves and make sure everything is buttoned up before Route66! Jim was manning the lap-top and making sure my MDS timing curves were just right.
HOWEVER, The new Milodon gear drive does not whine like the Pete Jackson one did. So for all of you that were in front of me, or are going to be in front of me, toss those ear plugs! The only noise you will here is the exhaust!
C U There @ Route66! Barb and I are leaving early so we will see you in Willimas for dinner!
There is No Replacement for Displacement.
U.S.A. All the Way!
Reason: updated gear drive info...
