Old 04-21-2008, 07:38 PM
SSSammy's Avatar
SSSammy SSSammy is offline
Default Hp to Wt?
Larry .. haven't had it weighed. Figure nominal ERA 427 spec at 2650 lbs with an iron FE and iron T/L. Me with an alum FE and alum TKO, and Billboard Goodyears which are like blimps and have negative weight .. maybe 2500 lbs?
So 2500/418 would give 6 lbs/Hp All I know is it will spin the tires all the way through first, second, and most of third. I just hope someone gets the film at turn 10 at Hallett when the rubber band in my sphincter breaks and I let off the throttle Ssshhheeeiiittt ...
I better shut up!
Sam
