Old 04-22-2008, 02:38 PM
Rick Parker's Avatar
There is a metal ring with holes for the flywheel bolts that is typically used with a flexplate in a automatic traansmission. If used with an aluminum flywheel it helps prevent the bolt heads from tearing up the aluminum. I highly reccommend it. Use application specific bolts,such as ARP or McLeod, not grade 8 Hardware bolts. Use red locktite.
Rick
