Old 04-23-2008, 06:20 AM
SSSammy's Avatar
SSSammy SSSammy is offline
Default Ride height and alignment
John, I had the ride height set to the specs .. 5.25" frame to ground front and 5.75" rear. I had it a little high because the right rear was rubbing on the body. Rob thinks that was due to the axle alignment, which he corrected. It wasn't easy .. the center section is in a non-adjustable cage. Ask me more when I see you next.
Sam
