Old 04-23-2008, 10:40 PM
JUS BIT JUS BIT is offline
Cobra Make, Engine: BDR #491, Red with Black Stripes, 438 Windsor by Keith Craft Racing dynoed at 640hp, Street and Race Prepped.
If you notice that the brake fluid lght comes on from sudden hard braking or turning, it is most likely a little low. The sensor is picking up when the fluid moves around. Just add a little and it should go away. We normally get our DOT5 from Oreilly or Advanced Auto Parts.
Also, if you are having problems braking, it may be water separated in the caliper. Try bleeding the system good starting with the furthest caliper to the closest.
These are great brakes. I use the stock calipers and rotors on my car and it has proven itself time and time again on the track. I upgraded my pads recently to EBC Red stuff, and I love them, no fade at all.
Bests, James
Radical Roadsters of Texas LLC
www.radicalroadsters.com
Backdraft Racing Dealer
281-804-5730
Watch out! You may get BIT!!!
