  #30 (permalink)
Old 04-23-2008, 09:41 PM
QUICKTIME QUICKTIME is offline
Default QuickTime
SFI allows a cutout for starter clearance as well as fork clearance. The argument is that the starter, when installed, will fill the hole and contain any failure suffiently. We have covers for the SBF currently (RM-6060-SC) and the FE and 460 covers will be completed in the next couple of weeks and offered as an accessory. These covers will give the housing a more finished look. The covers will bolt through the starter bolt holes from the backside and will adapt to any housings we currently have in the field. From a design standpoint, the openings allow for air flow to help cool the clutch package and can be used for clutch adjustments and inspection with the starter removed, most people do not see it as a big issue. We continue to make changes and improvements to make the product as flexable as possible. It is diffucult at best to design the perfect housing that will fit everyones needs because of the various applications. We have done our best to supply such a housing and are prepared to change if a better idea comes along.
Thanks again for your interest in QuickTime products.
Ross McCombs
President
QuickTime www.quicktimeinc.com
