Old 04-24-2008, 09:53 PM
bigrob's Avatar
bigrob bigrob is offline
Cobra Make, Engine: BDR # 126/ K. Craft 306 CID/375 HP- 306 RWHP
Originally Posted by Doc_Naughty View Post
BigRob,
Tire Works has a laser alignment rack and can do a four wheel alignment as long as you can provide the specs . . . front camber, caster & toe-in ( and back if you have IRS ). About $70.00. Seeing as your Cobra runs a BMW suspension, you should be able to just set it up as a BMW, right?
HTH
Doc (Pete)
I DO have IRS. I also have the assembly manual for my car with the Backdraft specs for the wheel alignment F&R. It shows the BMW specs, then at the bottom of the page are the changes Backdraft suggests.
Thanks Pete.
Rob
" Listen to that music! "
'65 BDR #126
'84 Porsche 928S
'01 Corvette C5 coupe
'99 Ford Explorer Limited
