Old 04-25-2008, 08:50 AM
Tony Aprile's Avatar
Tony Aprile Tony Aprile is offline
Cobra Make, Engine: SPF #1358 Silver/Black stripes 466 2X4
Charlie
You probably found the problem already, and the guy's gave excellent suggestions. I have run across a multi carb with a similar problem, the main linkage spring would close the front carb throttle plate. The rear carb after the linkage released tention was dependent on the holley incorporated throttle spring. The spring was not strong enough (for what ever reason) and would not close the throttle plate to the fully closed position...
Tony
