Old 04-25-2008, 07:10 PM
CWizard CWizard is offline
Cobra Make, Engine: SPF, 418 Stroker
Default Grease on Brake Pads
Let's suppose that a blob of grease found its way onto a rotor and then got deposited at the top of the caliper as the rotor turned, and then said blob got hot and oozed down onto the pad. So there's grease on the rotor and also on the pad. What effect would this have on braking? Reduce braking efficiency? Cause grabbing/lock-up on that side?
Has this ever happened to you, or am I just uniquely lucky?
Thanks!
